Toyota Trucks \  +38mm offset on 18x8?
Toyota Trucks Make Specific
views 375
replies 11
following 10
92yota   +1y
will i have any problems with these wheels tucking? thanks
tenagator   +1y
i was told aything from a +40 to +45 was ok to run
TwistedMinis   +1y
This is what I understand as well. Apparently +40 is pretty close to the lip. I got +45, hopefully that will tuck in my 2WD fenders.
dssur   +1y
offset means absolutely nothing without knowing the width. If, for example, a +38 7 inch wide wheel tucked, a +38 8 inch wide wheel would not. Just a note, if you want to help people, include width with offset. So many mazda guys think a +40 20x8.5 will fit because someone said once "+40 will tuck". Well, +40 on a 7 inch wide wheel, yes, but +40 on an 8.5, you will chew fender. Lots.
TwistedMinis   +1y
Okay, I have the same size wheel.
92yota   +1y
I could have sworn I have heard of people with at the most a +35mm offset but I don't know how wide their wheels were. Does anyone else know for sure if these will tuck.
deflaytedwayz2   +1y
+35 will tuck atleast i know it will with 4x4 fenders. i duno about 2wd ones
tenagator   +1y
your right i forgot to add the width of the wheel being 7.5 at the most so im told?
92yota   +1y
is anybody running 18x8 wheels on their truck that would know if they will tuck with +38mm offset?
2manytoyz   +1y
ive got a set of 20s with tires that will fit
