Acura TL Air Cans
Acura TL Air Cans
svlotoy
Who sells air cans for a 2000 Acura TL? My Girlfriend bought some cans but they were the wrong ones. So Were trying to find out who sells em. Just the cans. We have the brackets but not the right cans. THanks fellas.
sweeden's avatar
sweeden
how could the cans be wrong????? u need for inch in the front and 3 in the back. The only thing that could be wrong is the shaft size as far as I know
svlotoy
YEah the shaft size is wrong. They came off an eclipse, and we were told they would work. So the ends that came with the brackets we bought that are supposed to go on the cans do not fit at all. We tried looking into getting step down brackets for the shafts but no go.
F
frshryd
it sounds like your threaded ends, on the cylinder, are too big for the threaed holes in the brackets, is that what you are saying?
if so just make or get someone to make brackets with the right thread.maybe you can drill the hole bigger and retap it with the right thread.
if you have an adapter your car will sit higher when layed out.
svlotoy
Originally posted by frshryd
it sounds like your threaded ends, on the cylinder, are too big for the threaed holes in the brackets, is that what you are saying? if so just make or get someone to make brackets with the right thread.maybe you can drill the hole bigger and retap it with the right thread. if you have an adapter your car will sit higher when layed out.
We thought about that. But on the rear brackets the hole is offset and if we drill it out then we will drill out of the bracket. and on the front the brackets threaded hole is smaller then the threaded end of the can. We jsut have to buy the right cans. the TL's suspension is the same as an accord right?
Ih8bmps's avatar
Ih8bmps
I sell parkers this is the spec's
4.75" Stroke 80 mm I.D. Diameter
1/2 top and side ported
3/8 "3 wheel"/dust filter port
7/8 Thread Shaft
32MM Diameter Shaft
Fully Rebuildable there $114.00 each
