check valve
kevin.diel@yahoo.com's avatar
check valve
darkstar06's avatar
darkstar06
I have a question, can any one tell me how a check valve works and what is it for. I have a compresser that leeks and was wondering if a check valve would stop the air in my tank from leeking out of my compresser.
mobileheath's avatar
mobileheath
yup you should have one on there anyways...it'll save the seals in you compressor...check valve only allows air to flow in one direction...that is its only purpose
darkstar06's avatar
darkstar06
thanks alot.
SHOWTIME
YUP PUT A CHECK VALVE AFTER YOUR COMPRESSOR IT WILL ALLOW THE AIR TO FLOW 1 WAY ONLY AND WON'T ALLOW THE AIR TO BACK FEED AND THAT SHOULD CURE THE LEAK.
Low_SST's avatar
Low_SST
its like a flapper valve
i just got one that has an unloader built in so once the compressor stops pumping it releases the pressure between the valve itself and the compressor head...its supposed to help the compressor start up easier assuming yours isnt leaking like crazy. Grainger has them its called a Load Genie by control devices
part number 5a705
darkstar06's avatar
darkstar06
have you ever used fbi's check valves?
Low_SST's avatar
Low_SST
a check valve is a check valve its just a matter of how much you pay.
s10
last post by baha +1y
