Dodge Trucks \  360 in a 97 dak 2 wheel
Dodge Trucks Make Specific
views 217
replies 8
autohauskust   +1y
hey guys just needed some info on doin a 360 in my truck i have dropped the motor in but the oil pan hits the fron cross member i ordered the motor from the junk yard low miles and it came out of a 98 ram sst i also ordered an oil pan out of a 98 dakota its the same except for the drain plug is in a diff spot any suggestions
gravity5   +1y
the dakota oil pan should fit, because the RT dakota has the 360 in it....
autohauskust   +1y
i thought so too i have a 360 from a ss/t ram and its the same motor except the drain plug on the pan is diff location i even ordered a pan from a 98 doakta r/t it was the same dementions so the only thing i think im goin to be able to do to get around it is fab the fron cross member and call it a day
gravity5   +1y
maybe the RT dakota has a different crossmember, or the mount set the motor in a different spot check both of those.
lowrango   +1y
what motor mounts are you using? the 5.2 and 5.9 motors are the same size, and they don't have special frames.
autohauskust   +1y
i think that the 97 frame is diff i used the mounts from the v6 and it will lay rite in but the oil pan hangs too low and hits the cross member for the steering rack i ordered the pan from a four wheel drive its a shallow pan ill see if that works and if it dont ill make my own cross member
bdroppeddak   +1y
Edited: 2/4/2006 8:08:05 PM by bdroppeddak
i guess the 8cyl motor uses diff motor mounts than the 3.9, the easiest thing to do would either be section the pan and shorten the pickup, get the r/t motor mounts, or modify the mounts you have. i know the 6 cyl oil pans are like 1/2" or less off the ground, so i would go whatever route that will not let the drain plug go lower than stock
autohauskust   +1y
nah the mounts for the v6 and the v8 dakota are the same everything fits great except for the pan well now it fits perfect i got a new pan for a 98 dakota 360 4x4 and the picup and it fits like a glove i ordered it directly from chrysler the guy said 98 when they made th r/t the front cross member is curved out more so now im good i can start with bigger projects like my stock floor
autohauskust   +1y
