Braided Stainless Steel hose Size question
9
98on20s
I'am looken into doing this to my truck. my question is i want 1/2 inch line and i was looken at some Braided Stainless hose and the sizes that they list are in -4an -8an -10an and so on. How do i convert it to inchs??? Thanks
gravity5's avatar
gravity5
http://www.russellperformance.com/auto/hoses/pflex_prace.shtml copy and paste that, that is the russel page....
-8 is 7/16 and -10 is 9/16 ID....keep in mind that 1/2 inch dot airbrake line is actually 3/8 ID ao if you want that speed then the -8 is fine
9
98on20s
Thanks Aaron, thats the company i was going to go with, what do you guys think of russell performance or Aeroquip. i think i am going to go with -8 size.
gryte_racing's avatar
gryte_racing
well aeroquip has been around for a longer time, but the russel product is similar quality. the line is basically the same with what ever manufacturer but when it comes to fittings stay with only 1 manufacturer cause then they will look all the same, and when assembling the lines make sure you use a approved lube so you have less chance in the fitting digging into the rubber part of the hose. we build tons of these style hoses at my work for aircraft and the lube is a very important part!!!!!!
Low_SST's avatar
Low_SST
your using it for airline? How well does that work out?
gravity5's avatar
gravity5
Either company is fine, there is also parker, but most of them are rated to like 600 psi....and now you can get the polished fittings as well as the brushed Ti fittings from Mr gasket I believe......
Only downside is keeping it clean...dirt likes to get caught up in the braids....thats why I went hardline.....
You would be better off to hardline the parts you cannot see, then use the braided onyl in the areas visisble....cheaper too.
9
98on20s
Thanks for the info
