how big of a body drop can u go with 19s or stockfloor with 19s ???????/ u can lay 20s with a 3 3/4 body drop i was just wondering how far i can go....
impulse
3 3/4 is pst the pinch to the rocker right?
maddawg
it would be more helpful if you post the outside diameter of the tire you plan to use.
rizz0
3 3/4 is way past the pinch and into the rocker hard i think 2 3/4 puts you flat on the rocker
impulse
Excellent... thank you.
Now will a 19" still fit under there
rizz0
i am almost positive it will with a 35 series but if it doesn't they have a 30 series that is the same overall all an 18 so that will def fit and if you can get a 225 35 19 under it and have a spare 1/8 inch you can get a 20 under it with a 225 30 20
bdroppeddak
my truck was bodydropped 3" and i ran a 215/35/19, there was tons of room between the fender and tire.
rizz0
yeah it doesn't matter how big of a bd it is if you don't cut any of the rocker down. you can have a 6 inch bd and if you don't cut the pinch off you will still only lay pinch
4
4doormazda
thanks i was just asking what i should do i was thinking stock floor but how much drop will i get out of a stock floor .... i would like to go 4inchs on a stock floor a bd i havent put tires on my wheels yet...
