Audio/Video \  4 channel amp wiring
Audio/Video Q & A
views 166
replies 9
following 7
shagee2001   +1y
o.k. here's the deal... I have a 4 channel amp but one channel is not working. What would be the best way to wire the amp to 2 subs and recieve the best performance out of the amp? Diagrams would help alot. Off to work i go... check responses in the morning. Thanks!
Twisted Galant   +1y
well First it depends on what ohm load the subs are and if they are dual voice coil or not. $ channel amps suck for subs. Also does the amp have a crossover built in?
Twisted Galant   +1y
$= 4 channel amps. Sorry got a lil carried away with the shift button
hybrid showoff   +1y
bridge them to two of the working channels on the amp.
Twisted Galant   +1y
again that depends on what the ohm load will be
yourbabysdaddy   +1y
does the amp work in bridged(mono) mode with that one channel blown? alot of amps will not play bridged with a channel blown. what amp is it? what subs?
probably better off getting a bigger sub amp and using the 4 channel for what it was meant to do...highs and mids
Twisted Galant   +1y
thats right!!
SoDakminis   +1y
4 channel is a waste of time... put it on some mids or highs...get ya self a mono block
shagee2001   +1y
thanks guys.
