Mazda Trucks \  These god damn bastard bitch bushing
Mazda Trucks Make Specific
views 517
replies 14
following 10
FreelandKustomz   +1y
anyone have a clue how in the F*CK you get the lower control arm bushing in the frame out? ive been pounding and grinding and pounding and banging and they have not moved a fuckin millimeter, two days wasted.......not one bushing out and i have the other one to do. Please help
no regrets . wa   +1y
use a torch
balcar   +1y
lol, they are fun, here is a tech article on putting in some byc arms, I made a quick tool that did the job. I had one that was rusted allot and endedup using a sheetmetal sheer type of tip on a air chisel. But the tool that I built works for most.
http://www.lowdowncustom.com/tutoriaux-d4.html?os
boooghar   +1y
torch x 2
balcar   +1y
also, if you have allready used a torch, then this tool probally won't work because it pulls mostly on the rubber. Just a FYI
FreelandKustomz   +1y
yeah the rubber was shot, so all that outter rubber and metal has been cut off with a cutting wheel and grounded down. but ill check out this tech article and im sure it has what i need to know
FreelandKustomz   +1y
torch it is
FreelandKustomz   +1y
Hey Phil, which way do the bushings go out? twards the front of the truck, or twards the back?
j2thec   +1y
I had a problem with removing mine & I didn't have a torch, so I ended up drilling several small holes side by side to the pin finally collapsed in on itself. Hope this helps.
