93-97 Bodydropped ranger clutch master cyl problem ??
LX
lo xploder
My buddy has a body dropped ranger that is a 5 speed, 4 cyl and he keeps busting the clutch master cyl off the firewall cuz the tire hits it when he turns left. Has anyone encountered this problem and has moved the master cyl over or up or something?
awj81's avatar
awj81
I flipped mine around 180 degrees, now my resevoir is under the dash. I had to re bend the line from the transmission to the clutch cylinder. now the line IN is on top and the resevoir line comes out the bottom and into the firewall below the dash. I may try to get a pic tommorrow and post it up.
bodydropped85's avatar
bodydropped85
pics pics pics
sleepy
I moved mint on my 98 up and over a couple inches to clear the wheel. Just need to make a new mount for the rod to attach to the pedal. I also moved the whole pedal assembly to move the brake booster to help clear the wheel. Then I went to a hydraulic line store and got the right size flexable hose and cut the fittings out of the original line that ran to the slave in the tranny and hose clamped them once I fought them into the new line. Charlie
