Mazda Trucks \  302 Motor Mounts/Tranny/Rearend
Mazda Trucks Make Specific
views 81
replies 2
mazrod   +1y
I finally got my 302...Who on here has motor mounts to fit in a 92 2600i..Also do I need to change out my tranny crossmember to accomodate the new tranny? What rearend will fit to accomodate the drive shaft...The 302, tranny, and drive shaft is out of a 86 T-bird
jackson-vc   +1y
just get a set of universal weld in motor mounts from summit, most likely you will have to redo the tranny crossmember. the rear end that will match your tranny and drive shaft will be 8.8 found in all 80's fox bodied fords( mustang, t-bird, ltd 2, capri)
low mazda   +1y
your stock rearend will work unless you plan on doing a bunch of burnouts and everything. if all you wanna do is everyday driving and dusting a few hondas here and there, your factory rearend will work... unless your wanting five lug, then go with a yota rear and have a driveshaft made.
