2000 silverado going to 22s help
brian@illusivefabrications.com's avatar
slammedxonair's avatar
slammedxonair
is it possable to lay on 22s with djm arms with no balljoint problems
yumuggn's avatar
yumuggn
Anything is possible. The problem on the front is the width and offset of the wheels probably have to use a billet wheel with a high offset and a eight and a half inch width. the back you can use what you want you may fus hve to narrow the rear end. you might could use a eight and half inch wheel and make it tuck. Hit me back with any more questions. I can also get the wheels for you if you want. L8R
slammedxonair
our shop is doing our research on redoing a possable customers truck i was just wondering if the balljoints are gona bind up and if we would be better off just building a set. didnt know if anybody has done it on djm arms with out hacking it up
F
Fatdaddyrobnutz
It will lay with DJM arms, but the driver side hits the booster. Get spindles and put the stock arms back on and you won't have a problem.
LeidOutGMC
they will also provide lots of positive camber at ride hieght go back to stock arm with drop spindles like ^he^ said
slammedxonair
so it wouldn't be a good idea to run drop spindles and djm arms? pros and cons? i think i see what u guys are saying though thanks alot.
