rear brake lines??
rear brake lines??
red94toyota
what do you guys do with that brake system thing on the left side of the frame behind the axle on your 94 toyota pickups when you weld in a c-notch
time1's avatar
time1
i cut the hard lines and moved it right in front of my notch and made a bracket to hold it to the frame.
no1lowr's avatar
no1lowr
cut it off then weld back on when your done. hopefully out of the way of everything.
red94toyota
ok thanks
altnate
If your talking about the brake bias valve I took mine out and threw it in the bin, run the feed line directly to the rear brakes and remove the return line, there is a T piece at the front that the return line goes into, remove that as well and connect the remaining lines together, don't be tempted to use the T piece else where as it has a one way valve in it.
This is how I
