Adhesive spray on material
scrappinass
Hey guys, I was curious what kind of adhesive I can use on material in my blazer. I know 3m is good but not for interior because it gets hot as hell. Especially here in Florida. Whats the name and where can I get some. I heard about some at craft stores. I'm open for all suggestions.
SOINSANE
several times i have used this stuff in a can called tack-it. whatever you use try to stick(no pun intended)to using contact adhesive and not spray adhesive.you can always buy a cheap spray gun and buy contact adhesive in a bog'ol can and spray it out the gun.
glb7272
DAP
scrappinass
Thanks guys. Anymore ideas?
periportfd
Originally posted by glb7272
DAP
periportfd
Oh and like said above, get a cheap spray gun. After playing with the adjustments you can get it to spray out pretty nice. I do a panel at a time and clean the gun each panel. The glue starts to thicken up and collect around the nozzle pretty quick so just fill the cup with what you need and after your done with a panel pour the cup out and let the rest dry for like 5 minutes in the cup. Then just pull it out like a condom instead of wasting thinner. Run some thinner through the gun but also disassemble and clean. It doesn't clear out like paint so if you don't brush the parts it ends up a big snot inside.
scrappinass
Ok thanks. I'll go get some this week.
Madfly
Dap makes a good Hi Temp adhesive that many mobile headliner guys use instead of a spray gun. It comes in a spray bomb and will out perform most brands. Like you said it can get hot and basic foam and fabric adhesive will not hold for long.
