Dodge Trucks \  Relocating under the hood of a 00 Dakota
Dodge Trucks Make Specific
views 414
replies 11
following 9
Center Stage   +1y
welp these new fenders i've been waiting on for like 4 fuckin months from Dodge finally showed up today an I just went down an picked em up
well for you guys who already have done this, just lookin for a few ideas as to how i can relocate shit like the fuse box an all the brake lines an shit in the way right there on the drivers side. I want this as empty an clean lookin as possible
im probably fuckin up doin this shit right now cause all this engine swap talk has me debating it but when you havent driven your truck in months its hard to put off the last thing to wait even longer
definently would appriciate any help though guys
later
Jimmy
Center Stage   +1y
now im sure someone has to have some insight on this
bdroppeddak   +1y
i just made a bracket on the pass side off the frame to hold the computer, and made a bracket on the driver side to hold the abs and fusebox and the harness and hood latch cable goes over it, but that wont work for a truck that is more than layin frame on 20s. talk to josh on here he has the black ext cab on 20/22, he relocated his stuff out of the stock location.
bodydropped85   +1y
carburator
cantlooswit22s   +1y
mines not a dakota but,i moved the computer to inside the truck insted of on the firewall.im in the processof relocating the fusebox to under the wiper cowl (im getting rid of the wipers).my ABS shit isnt that much so ill just make and bend new lines to move it where i want wen i get to it.so the only wires that are really goin to be seen is the part of the harness that goes to the lights and shit.hope that helps you out jimmy alil bit.
Center Stage   +1y
brakes definently can just bend some new lines for , computer aint so bad, more so just the fuse box im worried about, i just cant figure where it can go an keep clean.
that is a killer idea though Ronnie
an Cris do you by chance have any pics of that all so i can check it out?
thanks for the input guys
fatheadjames   +1y
I'll try to take a couple pics today for you of mine. Not the best but maybe it will help a bit.
impounded dakota   +1y
It sounds like your already selling the dakota jim, but what levi did with the wiring on mine was, he extended all 52 or 53 wires almost exactly 2 feet each, re wrapped and re taped them all, then i losened the booster, and re-routed it down and behind the break booster, down to the frame, and followed the frame rails forward to the core support and mounted it off the core support in front of the wheel. Obviously not 100% hidden, but it serves it's purpose.
ricketspace   +1y
would it b possible to put the computer under neath of the front seat and run the wires under the carpet? this way at least the computer is out of the way and hidden
layedouton22z   +1y
putting all that mess away with 22z and a bodydrop is a pain in the ass. I wish i had a magical elf.
