Air Ride Suspensions \  5 gallon versus 3 gallon...
Air Ride Suspensions Q & A
views 319
replies 14
following 14
crazeflier07   +1y
Right now I have a 5 gallon tank in my trunk but I was thinking of switching the 5 out for a 3 gallon and putting my compressor right next to it to give me some trunk room again. If I switch to a 3 gallon will I still get the same performance if I run 200 psi as I did in the 5 gallon or will the smaller tank take away some of the time between the compressor running and it not? Thanks.
jabtay   +1y
Keep the 5 gallon...hell im running 16 gallons and want more
tofnlows10   +1y
i am running 2 3 gallons and 2 compressor...fine for me..
jabtay   +1y
Gotta love the EDCs!
groundbound   +1y
keep the 5.. its all about hittin switches for the bitches i have a 5gal with 2 vair 460's and it is not close to enough im upgrading
vincer   +1y
i have 2 5 gallon tanks
kevin@aac   +1y
3 gallons is not enough. You will only be able to lift your vehicle once. What do you drive?
forbidden   +1y
Keep the 5 bro...
kevin@aac   +1y
Or 2- 3gallons. Or a skinny 5 gallon. Dont go less than 5 you wont be able to get it up bro!
Ih8bmps   +1y
Edited: 2/15/2006 11:07:05 PM by ih8bumps
Chuck the 5 and get a 12 with two compressors... High pressure and more volume is what
