rear end help!
rear end help!
TIMS10PROG
ok i pull two leafs out the back and put 3 inch blocks and wen i take off it starts to shake rilly bad i mean real bad and when i go to burn out the rear tires start hoppin every were wat is rong
Hemi00x's avatar
Hemi00x
man i would def check your u-bolts man i rode with mine loose but mine shifted to the side when i took off... could just be that leaf is too weak but then again i havent had alot of experiences with pullin leafs but i mean everyone does so its got to be something loose to me... but i could be wrong
TIMS10PROG
no there tight its just if i let the clutch out to fast it starts to shake and everything is tight is there anything else
killersloth
I dont know what kind of truck you have but if it has a carrier bearing check that, it could be binding, or loose. also for it to hop when burning out probably has to do with you removing leaf springs
Hemi00x's avatar
Hemi00x
from hearing other people talking about pulling leafs(because i have not actually drove on a mono leaf) wheel hop is gonna be normal its just twisting i mean thats just something your gonna have to get used to when pulling leafs....
olskoolpup
yea, your pinion angle may be off if its vibrating while driving. vibration under hard acceleration is axle wrap, due to the pulling of leafs. and wheel hop is also caused by axle wrap.
to fix, have a stock set of leaf sprins de-arched.
other than that...youre looking at putting it back to stock or linking it.
s10
last post by baha +1y
