1994 FORD F150 I BEAM BAGGING
apowell94@yahoo.com's avatar
fordboy's avatar
fordboy
Does anybody bag an older F150? All I'm seeing is rangers. Are they the same? Does anybody have pics on how to do it? Also does anybody know how to wire in reverse glow gauges? The ac panel has a red wire and a white wire. The speedo has a red wire and a black wire. Any help?
baggedon22
the red power and black ground on the speedo hookd mine up to the headlight switch so when u pull it out they come on i dont have the ac one or get a volt reader and find a wire thats hot when the keys on and not when it off
1twztdwagon
slammedxonair's avatar
slammedxonair
make tube brackets if it has ibeams
fordboy's avatar
fordboy
I've got the round lowered i beams. How would I make the tube brackets for the top? How would the bottom bracket mount? I found a bracket from AIM Industries. Are they any good?
slammedxonair
do not buy ibeam brackets from aim unless u wana blow a bag and kill urself lol
fordboy's avatar
fordboy
how do you get the needles off the gauge cluster? do they just pull off? i got the ac face installed and it looks pretty cool.
baggedon22
i didnt take mine off just slipped the cover over them
fordboy's avatar
fordboy
thanks that helped out. i got them in and hooked up but sometimes they don't come on. you have to kind of play with the switch. i checked the voltage and it is fine. did you have this problem with yours?
baggedon22
mine do the same thing they work when they want to doesnt matter how u hook them up
