buildin a dodge
yeahimwt_21@yahoo.com's avatar
buildin a dodge
ExplicitCon3's avatar
ExplicitCon3
i recently aquired a 96 dodge ram 1500 hundred and im wantin to know the best place around indiana to get it bagged. im buildin this truck in memory of my dad. the truck was his and givin to me after he passed away so im needin good work.
Low_SST's avatar
Low_SST
there not terribly difficult to bag but if you really want to get into it have them shorten and raise your control arms and rear clip it. and rock some 24/26s
btw a old f-150 axle has the same bolt pattern but is 4" shorter so if you need shortening of your axle check out that route first
low95xlt
really yeea what yr does the axle need to be from?
Low_SST's avatar
Low_SST
the 90-94ish 9" f-150
there 5x5.5 bolt pattern and 4" narrower.
I
IsuzuChick
what r the chances in swappin a spidle from a ram to a dakota?????
Low_SST's avatar
Low_SST
wont happen. your best bet would be to adapt a toyota size one if at all.
ramslam1998
If you wanna do a dodge fullsize right be ready to shell out some money, because they dont make crap for our trucks
dodgemanwith20s's avatar
dodgemanwith20s
on that rearend do you have to change out any gears or does it bolt right up?
razorburn's avatar
razorburn
I gotta damn-near brand new Sir Michael's pan for sale for a Dodge. It's in primer and in perfect shape. Put it on ya cheap.
ramslam1998
my rearend come out of a 76 ford it has 389 i think and my factory gear was a 355 your speedo wont work though it runs of the speed sensor in the rearend
