Toyota Trucks \  Drive shaft hitting tunnel
Toyota Trucks Make Specific
views 154
replies 8
following 9
SinistarCustoms   +1y
We are bagging the rear of my friends taco. We havent started on the front yet it is just lowered. When the ass is laid out the drive shaft hits the tunnel,the x-member is already cut out. Will the cab have to be notched or when the front is laid out will everything even out? Its on 18's with 235/40's.
doordraggintaco   +1y
NEED TO LAY THE FRONT DOWN FIRST.ALSO CHECK THE PINION ANGLE.IF ITS WAY OFF THEN THE DRIVESHAFT WILL ALSO HIT.
sadisticiron   +1y
check pinion angle like he said. up to a 20 inch wheel,layin frame you shouldnt have to make a new tunnel but it depends on how its set up. once its b/d you need to tunnel it a little
sadisticiron   +1y
never thought of that good idea
Severed701   +1y
just Z the driveshaft
framescr8pintoy   +1y
just hit it with a hammer until it clears
whynotfab   +1y
haha
drag   +1y
That shit is funny
DntAskY   +1y
Notch the driveshaft
