Baggin a 1970 Chevy C-30
I have a 1970 C-30 (1ton truck, long bed). The truck as Drums on the front and rear. I am tryin to find out if i can use a 1997 front spindle on my truck!! I would be greatful for any help with my problem. I would also like to know if i need to go ahead with tublar upper and lower control arms? I wanna lay the chasis out on the ground. The biggest issues that i am tryin to figure out is if i have to go with a 71-72 front spindle or can i use a 1991-1999 front suspension!!
good question. i know at minimum the ball joints are going to be different. dont know
I'm sure you could with some modifications but you would proly be better off looking at an '81 to '89. I would think that those years would almost be a bolt on swap.
Yeah i was thinking that he could use the 81-89 suspension parts also. Should bolt right on so he change it over to disc brakes.
you can use control arms and spindles off the 73-87 trucks and they bolt right up.
then you have disc and no cutting, drilling or hassle.
you can go with 1/2, 3/4, or one ton and the arms all bolt up the same from 63-87 and to
whatever year thet stopped selling the square body dually...
