Questions bout Nitrogen??
low_tie_89@hotmail.com's avatar
bowtied's avatar
bowtied
Can i run nitrogen on a front back setup? I want to just run nitrogen so my second question, is do i have to have all the compressors and the tanks besides the nitrogen tank. I know you have to have the lines and fittings going to the bags but do i need compressors or tanks? Just some of the questions i need answered if you guys can help.
whynotfab's avatar
whynotfab
Yes you can have nitrogen for a front/back setup.. all that changes with that is the number of valves and all, Don't NEED a compressor.. but a good idea to maybe invest in a cheaper one.. even if it's a low duty cycle and cfm, just as a backup. I wouldn't run the nitrogen directly through your valves and into the lines/bags.. probably get a regulator and regulate the Nitrogen into whatever size tank you happen to find a deal on.. doesn't have to be big or anything, itll stay regulated at whatever PSI you set..
camberguy
yes you can and no you do not have to have compressors and extra tank it is good to have though.just in case even if you get a little compressor just to have as back up or just roll the nitrogen tank your call.
rdiracing's avatar
rdiracing
you should run a compressor also and a extra tank belive you will want to do that because i have been in the middle of no were and stayed without nitrogen and have to wait to you fill it up
s10
last post by baha +1y
