Nissan Trucks \  5 lug conversion
5 lug conversion
Nissan Trucks Make Specific
views 410
replies 5
NixMiNi   +1y
Exactly what all is needed to do a 5 lug conversion on a 99 Frontier.
NixMiNi   +1y
bump
impactsus   +1y
Front hubs and the complete rear axle from an 84 to 95 2wd truck and a custom made driveshaft.
downplz   +1y
http://www.nissanminis.com/modshop.php?mod_cat=9
check that out thats info on the front and as said above swap the new axle in and get the drive shaft made, it will give you a narrower rearend that the stock nissan
or you could re drill the stock rear
LaynRockers   +1y
That info for the front WILL trash your spindles! it will not allow the bearings to seat on the spindle and will wear a groove in the spindle causing it to break over time! I can machine the spindles for you so that there is no need for shimming the caliper as the forum above will tell you and it will allow everything to seat as it should. Give me a yell if I can b of any assistance to you....John
impactsus   +1y
Yeah, John machined my spindles and they worked great. Resonable price too. He can also redrill yor stock axles so you won't need to find a toyota rear either.
