Relocate???????
Relocate???????
Bdierks
93 Nissan Hardbody.......
Do i need to relocate the CLUTCH master cylinder in order to lay frame on 20's with 35 series tires.
if so, whats the best way to do it? is there a kit to buy or something?
Bolax
Just move the firewall back. You'll probably need the extra clearance to keep the tires from hitting it anyway.
Marcus
i just got done bodydroping my 97 hardbody and i need no know what to do with all the plumbing and wires on the passenger side.
SIC MADE's avatar
SIC MADE
I used one out of a Toyota truck I think it was out of an early 80's worked great still has to recess it into the firewall about an inch when I body dropped my truck though. Still a hell of a lot easier then using the stock one it's about half the size. I lengthed the whole wire loom in my engine compartment but a buddy of mine ran all his electrical down the passenger side of his frame looked pretty good to
baggedhb
move it inside the cab.
Bdierks
how do you move it what needs to be done exactly? any fabracation?
not bodydroping right now, do i still have to move it?
baggedhb
pull the assmembly apart and drill out the spot welds on the mount on the metal framing....slide the mount back and weld it back to the assembly,u will have to cut and move the clutch pedal some for it to feel right....then bored a hole in the rain tray for the filler part to come through it.
