Chevy/GMC Trucks \  350 small block in 95 s10 ?
views 135
replies 3
98sdrop   +1y
does the firewall have to be trimmed or modded in any way for clearance to drop a 350 small block with a 700r4 and all trans adapter motor mounts in the newer gen s10
dstrbn tha peece   +1y
yo bro, if the truck is stock height, or even lowered a bit, you should only have to bend back the lip on the firewall that leads back to the tranny tunnel. i body dropped my truck and had to trim a shit load out to get it to fit. so if your truck lays rocker or more, youll have to cut out a big section. best way for me was mount the engine, lower the cab down over it and just keep marking and trimming, then you get a nice tight fit. good luck man
hrc
98sdrop   +1y
thanks man, but im going with the stock body and have all airride tech product like the air bar and cool ride in the front with strong arms,proride big red valves,so i dont plan on layin rocker at all,guest im to old for the dragging steel thing.
minipu95   +1y
youll need a new tranny crossmember and have to shorten drive shaft
