Air Ride Suspensions \  77 c10
77 c10
Air Ride Suspensions Q & A
views 511
replies 15
following 11
johnz   +1y
what does it take to lay out the front on these bitches
oldskool86   +1y
unnnn either z the frame or section the front crossmember!
johnz   +1y
ok well we put 2.5 drop spindles and bags and its like 6 inchs off the frame and 3 from the xmember
oldskool86   +1y
hmmmm what size rims and tires u got on it?u might have to trim down the cups..
TwistedMinis   +1y
With 20s, you need to trim around 1.5" off the cups. Thats with a 1.75" sectioned crossmember, and it lays frame.
johnz   +1y
ok well its a 25 inch tall rim and tire combo the wheels are 15s...we used suicide doors brackets only one cup..lower one ..and conitech 2600s
oldskool86   +1y
hmmmm pretty sure u got to trim the cup down...i know to lay FRAME u either have to section the crossmember under engine or z the frame. the control arms will lay befor anything
johnz   +1y
ok thanks
DawgsledMazda   +1y
Z the frame 2&1/2" then cut 1&1/2" off the frome under the cab and it lays body with no body drop.
johnz   +1y
ok so just to lay out it needs to be zed no other way
