Chevy/GMC Trucks \  y pipe lower than trans crossmember what to do ??
views 362
replies 6
following 6
scoobwhooo   +1y
i have a 2006 crew cab silverado Bagged and all the crossmembers are raised to lay out but the Y pipe hangs too low in the front . where can i get another pipe for bagged trucks.any help would be great
Low_SST   +1y
i got mine all relocated which was a pain in the ass because i have a dual inlet cat versus a y pipe and i also got a turndown tip welded on and oil changed for 125
dB Zac   +1y
give up... the y pipe canot be defeeted.....
J/K
chicksdigit02   +1y
Local shop also did mine
mtm   +1y
see what the X and Z pipe have to say about it. The W pipe might be of some help as well.
scoobwhooo   +1y
the exhaust shop said if he raised it that it would be in the way of the trans to where you could not check it and he also worries about heating issues. what do you people think 2006 crew cab
wilddime   +1y
i had to take mine apart at the collectors, but I'm runnig headers, then shrten the y-pipe, and then weld it back, good luck. ~AA~
