92 full size gas tank
txschvy@aol.com's avatar
txschvy's avatar
txschvy
I need to raise my gas tank but there isnt enough clearce to the bed floor to do this. Any way to fix this with a replacement tank or any thing else. I really dont want a fuel cell in the bed and i dont have any room at the back of the frame due to the four link. Somebody help me out cause this is the only thing keeping me from hittin the ground!
2LOW4U's avatar
2LOW4U
I just extended the lines and put my factory tank in the bed for now, its ghetto but it will hold till i get some money.
bdroppeddak's avatar
bdroppeddak
ive got a 94 ext cab and mine went up almost and inch without touchin the bed.
lowxclazz
ive dragged through mine numerous times. i guess ill be sticking mine in the back of the truck shortly. at least until i sell it.
you should be able to notch the crossmember holding the tank about an 1" and just tighten the bolt all the way until you cant. it will raise back of the tank so you wont drag through it...i should have did this when i could.
txschvy's avatar
txschvy
I had to cut the cross member and part of the cab to get enough clearance for me to be comfortable with it but it worked.
Onelofullsize
i have a 90 i bought a tank from an s- series blazer and put it behind the axle fits right in between the rails and looks real good
jcbrob's avatar
jcbrob
i have a 96 full size stepside will the factory fit in the bed cause the bed
BS
beyond static
notched the crossmember, shortned the strap, and raised the back of mine a little over an inch. I drag the piss outta my truck, and it doesn't drag
