3 or 4
3 or 4
BM
Big Mark
just tryin to get some other peoples oppinions should i put 3 or 4 jl audio w1's in my truck i am only running a 500/1 to the subs so it should be ok in power just wonderin if i should spend the extra 100 bucks on the 4th sub
Jance Customs's avatar
Jance Customs
I have only heard a few of the new W1's and I am impressed with the sound quality of them. If you like the heavy bass I would go with 4 of them depending on what truck they are going in. I am going with two 12W1's in the future which is plently for what I want. If you go JL you can't go wrong!
lowrthnu92's avatar
lowrthnu92
id go with 4 , cuz if you get 3 you might want a litle more later on , if 4 is too loud just adjust the amps and the bass levle on the radio
BM
Big Mark
^ that is true...
1BadBlazer
Well here's the issue that comes up with that. The W1s are single 4 or single 8 ohm voice coils. The 500/1 I know is rated for 4 ohm usage and I would suspect that it can run at 2 ohms as well.
3 4ohm W1s will put your amplifier running at a 1.333~ ohm nominal load in parallel wiring. This may be ok with that amp and it may not, I have no experience with the JL amps. 3 8ohm models would give you 2.67 ohms which that amp would be more at home with.
Now, if you went with 4 subs your final impedance will work with that amp better. 4 4ohm models would put you at an even 4 ohm load to the amp in series/parallel wiring. 4 8ohm subs would give you 2 ohms in series/parallel.
And you can't mix subs of different impedances with optimum results. So choose wisely what will work with your amp
