ranger feels wierd
ranger feels wierd
tbmx86
everytime i come to a complete stop my ranger sort of feels loose. like some bearings or somethings not tight. I cant figure out what it is. The best thing to compare it to would be like riding a bicycle with a really loose headset. Any ideas what it could be? My check engine light came on too last night. ANy ideas?
mtm's avatar
mtm
bicycle with headset huh?
dragn168's avatar
dragn168
id check where the ibeams connect to the frame may be the bushings are loose or really worn? if not them id check the hub and brake assembly but i really dont know that could be whats up
SSM-Webmaster's avatar
SSM-Webmaster
Sounds like part of your suspension is loose check all your bolts, and also make sure nothing is in the bed that can move around. As for the Check engine light I doubt it has anything to do with your truck feeling loose, you should be able to get the codes read for free at AutoZone if you have one near you.
clenzer72
check you camber washers. i had that problem on the way to my alignment when i lowered it.
W
wizard8575
keep driving it till it falls off then you will know what it is.
grillift
check your camber nuts. mine came loose and the front end was super wierd feeling.
gonz's avatar
gonz
Edited: 2/28/2006 8:12:31 PM by gonz
if you have bushings in the link setup check those. my friends ranger had a parrallel 4 link and all the bushings were wore out causing his axle to sway badly when coming to a stop. it shook the whole truck.
Grounded 4 LifeGonz
tbmx86
it has to be something in the front. my rear is fine. And i can feel it significantly in teh front passenger side. Im going to pull the wheel tomorro wnad check everything everyone said out. thanks guys
