Taking cab off 89 silverado reg cab. info needed
bagged2200
If you have taken a cab off of silverado how much work is involed and how long to take it off i figured i get some pointer before i started thanks
I
Idragit
not too bad..emergency brake cable..cab mounts...steering shaft..disconnect brake booster from master cylinder..unplug wiring bulkhead on drivers side..thats the most of it..if your pretty good at mechanical stuff you should be able to pull it off in a full day..actually getting it lifted up and the frame from under it is the hardest unless you have a lift or other equipment
tealchevy's avatar
tealchevy
you probably picked one of the easiest trucks to do
BadAssChevillac's avatar
BadAssChevillac
yea nothing to hard as chris and dusty said, just need a couple of guys to lift the cab off. or a lot of hot naked chicks would work too!!!
bagged2200
sounds good to be thanks yal starting tommrow takeing it apart
