4 link questions
dodgeman200236426@yahoo.com's avatar
4 link questions
dodgeman's avatar
dodgeman
My truck is in the shop getting bags and im getting kinda worried, a few people have said that the airride parallel 4 links wont let you lay frame in the back. I dont know how true this is just trying to figure out what is going on. I dont want to get something bagged and then not be able to lay on the frame or crossmember. Also what do i need to worry about as far as driveshaft problems if any. One more thing, is there any dakota owner that has dragged with the gas tank in the stock location, i figure it would hit, but im not sure and if it does hit can you raise it and still use the stock filler door Any help would be appreciated, thanks.
Low_SST's avatar
Low_SST
you would prolly have to worry more about wheel offset then anything and axle shortening is a possibility. anything liek the gas tank that is below the frame will need to be moved.
dodgeman's avatar
dodgeman
Yeah i went to the shop today and looked at it and the tank is going to have to be moved the only problem is that my truck has already been painted and i didnt shave the gas door, i could put a fuel cell or the stock gas tank in the bed but im worried about safety issues there plus it would be kinda stupid to have the gas door and not use it. Lol man i didnt know relocating a gas tank was going to be this bad.
bigjon's avatar
bigjon
lots of places make replacement tank that fit in the factory location. (DEVIOUS) or you can section the factory one to fit then you dont got to worry about the factory gas door.
kotalaynframe
MINE LAYS FRAME IN THE BACK AND MY TANK IS LIKE A INCH OF THE GROUND I HAVE THE STOCK PLASTIC TANK BUT I ALWAYS HAVE LIKE A 1/2 INCH BLOCK WELDED ON TO DRAG ON
Snakesunlimited's avatar
Snakesunlimited
LOL...
dodgeman's avatar
dodgeman
Well i got the gas tank taken care of, im just going to opt for a fuel cell, possibly diamond plate just depends on whether the shop that its in has time to make it or not, i really dont care though as long as it will hold gas and its safe, i just want it in time for spring fling
