Air Ride Suspensions \  valves
valves
Air Ride Suspensions Q & A
views 278
replies 10
following 11
CRAIGSdime   +1y
sometimes my GC extreme 250 psi valves dont close all the way and leak real slow, is there any way to fix them or do i need new valves?
forbidden   +1y
I hear some people cleaning them with wd-40.. Might try that.. I hear that the 250's have that problem. If you end up going with different valves check out the Asco's cheap price and killer performance
BlazinKuztumz   +1y
I wouldn't use WD-40, it has a tendency to dry items out after it evaporates. Try some tool oil, it will stay lubricated and will still help you clean all of the parts up.
lowrthnu92   +1y
air tool oil or mineral oil , takem apart clean the diaphram and lube it up
if that doesnt work call up GC and tell them, theyl take care of you
laidout94toy   +1y
I just met someone on Saterday who had problems with GC's sticking, I have Blitsluft valves for like 4-5 years now and never have had any problems.
periportfd   +1y
What is the pressure in your tank when this happens?
lowrthnu92   +1y
the GC 250s are known to be leaky , there first batch had issues
LAYDOUTYOTA   +1y
I have e-valves and they do the same thing I will try the air tool oil trick . hope it works
bagganddrag   +1y
get some tork valves from If Customs or psycho customs they both sell them i run them on mine they work great and they r a closed design
sinwagon   +1y
Any valve will leak if it gets debris in it. Take the valve apart and clean the diaphram and spring out with some soapy water.DO NOT use wd40!!! Use non chlorinated brake parts cleanerto clean the body of the valve.
