Air Ride Suspensions \  ?s about hydro pumps
Air Ride Suspensions Q & A
views 117
replies 5
following 6
blazenide89   +1y
just wanted to double check can i mount these bad boys upside down?
jetts   +1y
yea, aslong as the fluid is getting to the motor. have fun trying to put fluid in there
shavedmax   +1y
are you trying to hide them? that would be the only benefit i see to mounting them upside down. otherwise your maintenance is gonna suck. you can invert the tank so the opening is on a side or bottom, but i would make a bracket to hold it right side up better, this way if you do iahe to do any work to them, just drop the bracket
Minty Fresh Maz   +1y
I dunno were your gonna put um...but
What if you hinged those bad boys (or their mounting setup) so they hung like a horse and went up like a rabbit LoL
Just a Though...L8
juicedwagon   +1y
i think he means mounting them like that 300c that lays on 22's. they mounted the pumps to the top of the trunk. just take the tank off and flip it so you can fill it up.
dragnmy61cadi   +1y
can you imagine trying to bolt the pump in holding that heavy ass thing till you got the bolt started? and the oil pick-up, on the pump, can you flip the pump inside the tank. or is the pickup going to be on the topside of the tank now?
