22"wheels question
22"wheels question
tucn1ton avatar
tucn1ton
I've got a 87 suburan and want to know, will a 14mm offset work on a 22x9.5 with a 5.5 back space?
Dragthatchit avatar
Dragthatchit
yes!!! ive got a 89 suburban set-up to lay the rockers and it has a 22x9.5 all the way around. it also has a 305/40-22 tire in the rear. its a tight squeeze when the rear is all the way down but it does work just fine at ride and draggin heights!! And no, i havent narrowed the rearend if thats what ur gettn at
blazedout84 avatar
blazedout84
worked on my s10....so it should on a full size
tucn1ton avatar
tucn1ton
thanks ,I've got 265-35-22 all the way around .that should work hopefully .O and it lays rockers.
