Body work and Paint \  Air compressor ?'s
Air compressor ?'s
Body work and Paint Q & A
views 771
replies 14
following 10
drptndrgn   +1y
Whats needed to do a "at home paint job"? As for compressor wise.. WIll a compressor with 1.7hp 5.6 SCFM @ 40/90 PSI. 150 PSI max work allright for a decent primer job?
quwheestalon   +1y
yes HELP please!! Compressor size???
What your size's CFM/tank/psi/hp are you all running in you garage/shop? I don
idminitrucker (jason)   +1y
I love my compresser all but the price it is a Snap On but it is made by Big Red Air it is a 80 GAL 175 PSI two stage 28.5
CFM with a 7 HP 220 motor i can run a DA or a paint gun and it will start and shut off while im using it. Get the biggest one you can afford it will be worth it in the end.
quwheestalon   +1y
Thanks how small is to small?
to small it kinda up to you how much do you want to hear it run and how much do you use air tools. i would stick with with at least a 175 psi compresser you can get some nice ones at sears the oiless ones are louder because the bottom of the pistons are open to cool it because there is no oil keep that in mind when you buy one
jmfknpizzle   +1y
if you look on tag it should tell you what is recommended for each tool.I would say you need atleast a 60 gal compressor to be safe and have a decent psi. but you can try smaller i wouldn't
quwheestalon   +1y
Thanks guys any other advice? This is one investment I don
nvrdoned50   +1y
get 2 Viair 380's
jmn444   +1y
that link just brings up lowe's home page for me...
