upper front bag mount positioning
royaltz2001@aol.com's avatar
tenagator's avatar
tenagator
ok i took out the old setup that was in it, man was it all fd up i dont knwow hat soem people are thinkin?anyway where is the best palce to put the upper bag mount? i have the upper stock control arm still welded on but i cut off the part where the shock bolted up. i have soem frame under the mount where i can weld it in but im wonder where is best so i get good drop and good lift? pics will help. thanks guys
whynotfab's avatar
whynotfab
Basically you just jack the lower LCA up as far as it'll go, and go from there. Weld lower bracket on, the space the upper from that according to what bag you have. I have some pics up on my site of my front install. Check em out if you want, Good luck bro
tenagator's avatar
tenagator
well i got KW uppers and lowers and will be running 2500's with 215 35 18 tires if that will help.what i plan on is bolting the bag to the lower mount, then the top plate will get bolted to the bag jack up the lc arm and see where it line sup the best parallel to the lca
