Chevy/GMC Trucks \  00-05 burban suspension
views 136
replies 9
following 6
b12yan   +1y
is the burban suspension the same as a fullsize truck of the same years... just curious about spindles and such...
draggindimes   +1y
should be. they are basically the same chassis, just different body
b12yan   +1y
i figured so but i know blazers and s10s run different spindles so i was seeing if there are small differences like that... anyone else?
b12yan   +1y
well i found out the front is a torsionbar setup...
kboring   +1y
The rear is a trailing arm setup with coils I believe
lowboy msports   +1y
i BELIEVE THE SUBURANS ARE TORSION BAR, WHERE THE PICK UP IS A COIL SPRING.
tealchevy   +1y
different
b12yan   +1y
yea your correct on that.. any good pics of any layed out besides the grey one in truckin?
draggindually   +1y
Front is Torsion Bar style, I believe the upper control arm mounts are lower than a regular Silverado. Rear is basically a parallel 4 link with panhard. I had to swap a frame out on an 02 Sub when I worked at the bodyshop.
b12yan   +1y
think it would be much of an advantage to swap a clip for a fullsize truck... just to get rid of torsions and all.. basically want very little camber don low with very good lift..
