Air Ride Suspensions \  watts link question...
Air Ride Suspensions Q & A
views 98
replies 3
OneLowTaco   +1y
actually my question is how does it work with a 4 link already installed if ur axle pitches forward and back hows these extra bars make it go str8 up n down then another question.. do u even use it with a 4 link or better with 2 i dont really hit sides that often with my truck does that have anything to do with it also
renny   +1y
you might want to contact clint petree at 1866kplinks im sure he can answer your questions.
Ih8bmps   +1y
It works with parallel 4-link set ups...If your 4 link is installed right the rear should stay pretty straight through out the full range of movement...In the old Rx7's it had a tringle 4 link style set up...There were two link bars at the bottom of the axle and to shorter bars at the top with watts link...I've seen guy's running two link's with watts linkage,but to me its just not the ruight way to do it...
DawgsledMazda   +1y
the watts keeps the axle from moving side to side, not front to back.
