air craft remover?
X
air craft remover?
1989dangeroustoy
im using aircraft remover to take my old paint of,but i think it will eat out some of the bondo spots, so what should i do, should i put masking tape over the spots or use something else????
baggednbad91's avatar
baggednbad91
well, im guessin that since youre removing the paint you must be prepairing to repaint it, so why not just redo a lil bondo whil youre at it?????
jmn444's avatar
jmn444
ummmmm, if the paint quality is bad enough to strip it, you probably ought to redo the mud under it too.
But yes your right, it will get into the mud, and if it does you'll have no choice but to remove all the old shit too.
1989dangeroustoy
no, i just finished the bondo but i need to strip the rest of the paint off cuz i bondo'd it and primed over those areas
jmn444's avatar
jmn444
Yup, you got the right idea then.
I use duct tape when masking for stripper, seems to work better.
mtm's avatar
mtm
i sprayed that stuff on .030" thick powder coating before and it fell off in about 2 minutes, i'm not so sure masking tape will stop it.
jmn444's avatar
jmn444
yeah, i usually brush it on and use the duct tape for an edge... no reason to spread it on top of the tape...
1989dangeroustoy
ok cool, thanks guys
200bodydroppedrangr
tape stoped my areas perfect. almost a clean line also.
