s10 on 19s BD ?s
s10 on 19s BD ?s
luv2sprk
im BDin a 93 s10 right now and i think im gonna have a problem with the a-arm hittin the clutch master cylinder. the truck has 19's and the a-arms have been pie cut so the ball joints are re-angled. anyone else have this problem, and whats the easiest way to get around it using the factory clutch master cylinder? thanks
luv2sprk
bump
TC29720
You could move it over a bit, enough to clear or ty to recess it into the firewall
BB
bill brasky
Yeah all you have to do is move it up and recess it into the fire wall a couple inches using a pipe.
luv2sprk
ok thanks, what about the fuse block/wire harness, where do yall move that to?
david49910
under the dash
BB
bill brasky
Or you could cut out around the openings and reweld them in under the brake master cylinder in the fire wall.
