Air Ride Suspensions \  ait bags.
ait bags.
Air Ride Suspensions Q & A
views 317
replies 11
following 8
xMariox   +1y
ok well guys just another little question i got for you. im just wondering when i life my truck up it seems that it raises very slowly, espcially the front. it drops down nice and fast just raising seems to take a lil time. i checked if anything is binding and it all seems to be ok. im not sure what else it could be. oh yea i have firestone air bags and im using spool vavles if that makes a difference
Lonoma2k   +1y
firestones will lift a little slower than the stiffer bags like Slam's will, b/c the sides pooch out as well when u fill em up, which also takes away from full lift potential, Ive never been a fan of spool valves, but i dont know if that would make it any slower tho...
xMariox   +1y
well the rear seems to lift not so bad, but i was just thinking because theres no weight really in the rear. and the front was just lifting slower because of the more weight on the truck
xMariox   +1y
and im guessing what your sayin is there would be no way of me fixing this unless i use differnt brand bags?
xMariox   +1y
bump..
down2earthdawg   +1y
you answered your own question so I would change your valves or changed your bags
MRCO   +1y
you didnt specify what pressure you were running at.
my first reaction is to say more pressure.
forbidden   +1y
Yea bro the front does take a lil longer than what the rear would because of the weight difference. Slams would lift somewhat faster because they are stiffer..
xMariox   +1y
ive run 150psi on them and still slow no matter what pressure there at. but thx, by the sounds of it, it just must be the firestones i got. il just have to live with it until it comes time to change them. thx for the responses
WickedBird   +1y
many times if you increase the volume it will fix the problem. Pressure doesn't matter if you don't have a enough volume.
