dssur
Originally posted by SPICY
IF I AM STOCK FLOORING THE TRUCK 4" AND I HAVE TO Z THE FRAME 2"
I'm not sure you can, or even need to, stock floor a tacoma 4 inches. The factory frame is only 5 inches tall if I remember.
And coincidentally thats how you get some drop BACK. So if you make the new rails as low as the factory engine crossmember, you are dropping the new rails an extra inch or an inch and a half, then when you use 3x2 rails it works out to be a (stock rail 5 - new rail 3 = 2" ) + 1 1/2" "Z" = 3.5 inch stock floor bodydrop. There have been a ton of Tacomas stockfloored this way. To do a 4 inch stockfloor (without the z, like you said) you would need a 1 inch tall frame.
Then you only have to lower the motor slightly to clear the hood, a 3 inch traditional bd on a taco only interferes slightly with the stock hood.
