Standard offset/backspacing on PUP.
V
SN
SHORT n SWEET
I did a search can't seem to find anything.
All I want to know is what is the standard offset on ISUZU PUP steel rims?
I am looking at a set of 22's for my newest truck but I am leaving it 6-stud, my other pup is 5-stud with drop spindles and needs +45.
would +15 be ok?
dragn168's avatar
dragn168
i deffinitly need to know the back spacing for the rear stock sheet metal if it tucks back there it'll tuck up front
olskoolpup
i doubt that +15mm would be ok. those are for fullsizes.
the only pup i know of w/ 22s are billet, and probably only 8.5" wide. usually gotta run about 6" of backspace with that width rim.
i know my truck is different, but my rear wheels tuck like 2" more than my front.
dssur's avatar
dssur
+45 at what width
+15 at what width.
Need to know widths, +45 on a 7 inch wide wheel is 5 3/4 backspace. +45 on an 8.5 inch wide wheel is 6.5 inches backspace. They have diferent frontspacing with the same offset, so one might fit, and one might not.
To quote backspace or offset you have to state width, or the numbers dont mean anything.
I had an isuzu once, and ordered 7 inch wide wheels with 4 3/4 backspace and they tucked great. That is a 3/4 inch offset, so +19 on a 7 inch wide wheel would work.
That backspace means anything with a 3 1/4 FRONTSPACE will tuck (7 wide + 1 inch for the beads = 8 - 4 3/4 backspace = 3 1/4 frontspace ) so you can figure out ANY wheel width. An 8.5 inch wide wheel wis 9.5 inches wide, - 3 1/4 = 6 1/4 backspace. To get offset from that number, 9.5 / 2 = 4 3/4 is the wheel centerline, 6 1/4 backspace - 4 3/4 center line = 1.5 inch offset = ~40 mm offset on 8.5 wide. With 20's though I would get as much as I could, so that should be the MINIMUM you should find. Body dropped maybe a half inch more to clear the inner bed side, or +52 on 8.5 wide.
Sorry for the math lesson but it really is simple once you figure out whats going on.
dragn168's avatar
dragn168
russ-d its reasons like this that you rock i was thinking of going 18x7 or 20 by 8 i hope i can figure this shit out
mmrcustoms's avatar
mmrcustoms
can i put 20 off an 2002 surban on my pup it is an 89
SN
SHORT n SWEET
I was going to work it out once i had the stock wheel width and offset details...
the wheels i want are 22x9.5. with a +15 offset. RUss-D you are the math man can it tuck???
olskoolpup
a 9.5" wide wheel is actually 10.5" wide with the beads. center line is 5.25". 15mm=.59". therefore frontspace is 4.66". Russ said youll need more like 3.25" frontspace.
no dice. they wont tuck
with that wheel youd need at least +50.8 offset.
CLNSHAVN
dude just be sure whatever you buy will fit. Cause like someone said earlier 15mm offset is for a fulsize, and i know i have 15mm offset on my pup and had to make my own damn fender flares. And if you lookin to tuck 22's i would call billet specialties direct, intro, or someone who will make you a set of rims on your specs for your truck.
Related Discussions in Isuzu
