Baggin a 1970 C-10
dr_layinlow@yahoo.com's avatar
Baggin a 1970 C-10
layinlow78's avatar
layinlow78
I need to know if i need to change my control arms to tublar or not if i am baggin my 1970 Chevy C-10!! I have been thinkin about going with 22 inch wheels or 24 inch wheels on my truck!! We are going to make the truck lay out on the frame!! So we need to know what to do about the control arms and will the wheels hit anythin in the engine compartment!!
oldskool86's avatar
oldskool86
im pretty sure u can use stock arms
dragginsteel67
Edited: 3/9/2006 5:26:32 PM by dragginsteel67
you could prolly lay on 22's with just either z'ing the frame or doing a crossmember notch, without one of the two you won't lay frame.You could prolly get away with stock arms. With 22's you will most likely run into problems with the hood hinges and of course the inner fender wells will have to go. I really don't know bout 24's, might be too tall to fit in the fenders/under the hood. I know for 20's you have to trim the fenders and hood hinges, so 22's or 24's I'm sure you'll need more cutting............
