2600s in the front
2600s in the front
bodydrop99ranger
whos runnin 2600s in the front of ther 98-2000 ranger and how much lift are you gettin?
couldbelower
i have 2600s....i am runnig 20s and got the 3.0..i wouldnt even consider smaller bags then 2600s
low99maz's avatar
low99maz
I have 2500 slam spec. bags up front on a 99 maz with a 2000 ranger frame and get more lift in the front than I do in the back with a super lift set-up. I get so much lift in the front the positive camber is crazy, dont know why you would want more!
couldbelower
i dont think the amount of lift changes all that much from 2600s to 2500s because of the way the radius is set in the front fo a ranger..maybe on a s10 or in thh back where the bags lift straight up but since they are on a serious arc when inflated it wont really change.
foreverlow01's avatar
foreverlow01
i just bagged the front of a 99 ranger and we put re6's on the front and its bottoming out the front, it can't go any higher cause the top arms are hitting the frame and we've got upper and lower control arms
bodydrop99ranger
y im askin is cuz i got a 5.0 in it im running 20's on it and im bodydrop 2 1/2in and my frame is z'ed 2 1/2 in to. i just want to make sure i can untuck the 20's.
complexdesigns's avatar
complexdesigns
I am running 2500's, the 26's are just so damn big and unneccesary.
chunky_thunder's avatar
chunky_thunder
i am runnig 2600s on mine and it is bodydropped now and i have the 4.0 sohc on 20s... i can go about 3 inches more than in the pic
bodydrop99ranger
do you got stock c-arms or aftermarket i got stock and im lay full frame on 20's.
