hey just bought a mazda 2600i dont know much about these. need to get the get the frame on the ground with stock arms and spindles is this possible if so how. got the ball joints flipped. what else can i do. thanks
Take out the bump stops and cut
the mounts off. Did you take your torsion bars out? There is a bolt that holds each
one in. Take tose out and your bars should
pull straight out of the lower arms. You
might have to use a hammer to get the out.
your frame should lay in the front now. In the rear install a 4 link.
u planning on bags or something first, if you just lay it out, you won't be able to go anywhere. mazda b2200 and b2600i 2wd are the same for droping FYI...
Take out the bump stops and cutthe mounts off. Did you take your torsion bars out? There is a bolt that holds each one in. Take tose out and your bars should pull straight out of the lower arms. Youmight have to use a hammer to get the out.your frame should lay in the front now. In the rear install a 4 link.
that deffently the long and the short of it when BD ask what type you are going to do so we may help you in your quest for being LOW!
