running nitrogen
running nitrogen
X
XpLower
What involved in running nitrogen, I mean what do I need? Do I still need a compressor, or tanks, or any special valves? Any help is apriciated
TuKnRaiL's avatar
TuKnRaiL
No special valves are needed and you can run a compressor if you want you can use it for a backup if you run out of nitrogen so i guees if you run a compressor you will need a tank!!!
whynotfab's avatar
whynotfab
Youll need the bottle of course, some kind of bracketry to secure it safely, a regulator to regulate a constant pressure to a regular air tank. after that it's pretty much up to you if you'd like a backup compressor.
lo75lux's avatar
lo75lux
u dont really need special valve, but u wanna make sure they can handle the nitrogent, my mac daddy 450's do just fine
taylor41
can you run nitrogen off of mic manual valves and will that speed the setup a little bit throught the small valves?
s10
last post by baha +1y
