friend bagging an acura RSX.
gonzorelic@hotmail.com's avatar
gonz's avatar
gonz
my friend is looking to bag his 03 rsx. only problem is i cant find anything to bag it with. ill get all the managment stuff easy it just the strut replacement. does anyone make cylenders or bolt in bag struts for these cars? do they have the same chassis/susp. as the newer civics? i need some info. i havent seen 1 bagged RSX. ive looked everywhere. i just dont think there are any. i seen 1 on dros.
dawgpimp's avatar
dawgpimp
cylinders won't work on the front. the steering arm is on the strut. no strut, no steering. it will take some fab work to put them on the rear. yes the civic and rsx are the same.
gonz's avatar
gonz
i called eai and talked to a guy that said he has a kit for the car but it requires fabbing on it because if just bolted in the car laid out will be around stock height. also how is a strut/bag going to work on the front if a cylinder wont?
soontobelayed
yeah i had a customer with a 01 civic and they said the same thing and then they told him to cut his strut well lets just say that was a dumb ass idea you will have to do strut bags prob for a civic or integra and make thim work unless they make them for an rsx
madlowmazda
you should call kustomwerks, or see their website. They made some air cylinders for an element, which shares a similar suspension design to the newer civics and rsx's. They might be able to modify that design to work with your rsx. Their design incorporates a new knuckle to bolt the tie rod to.
