Foreign Cars (honda, etc) \  Shaving inner tails...
views 236
replies 10
following 9
drptndrgn   +1y
Anyway to wire your reverse lights into your blinkers when you shave the inner tails on a civic so you dont lose your reverse lights??If so can you run them off the same bulb?
drptndrgn   +1y
No one knows??
99hondagrl   +1y
I'm no expert at this, but how in the world could that even work?
drptndrgn   +1y
Thats what im asking... I figured since your backups arent on when your blinkers are you could run the reverse power to that buld to illuminate it while in reverse... I was curious how you get around the no reverse lights if you shave your inner tails
krazeryn   +1y
I'd say no....but you could just add another bulb into the outer tailight housing
TUKIN18S   +1y
I would say no too. Fuck reverse lights!! I didn't hook mine up.
vegasnotnormal   +1y
I think you should be able to. but you would have to find a dual lit bulb. jut like a headlight. wire your power wire for the blinkers to the low beam and wire the power fro mthe reverse to the high beam, and then ground the third wire. that should work, but I have never tried it, so I'm not positive. Your normal tail lights are dual bulbs so I would assume it would work.
dragn168   +1y
why do you need reverse lights? just lightly apply the brake as you backing up its alot brighter than reverse lights any way. or do you need them for an inspection?
XpLower   +1y
FUK reverse lights, who needs them. In my other truck, I had caddys, with no reverse light, and never had a problem,leaving partys drunk and all, just tap the brake slightly like Anthony said, it'll be all gravy, and fuk inspections, my state dosn't have them anymore, hahaha
frshryd   +1y
some times you do signal when you reverse.
i would either add a bulb in the outer housing or screw it. how often do you back up anyway LOL
