Chevy/GMC Trucks \  Fullsize on 22's
Fullsize on 22's
views 232
replies 7
following 6
banginfullsize6   +1y
I have a 95 f/s gmc. What all do I have to do and modify to lay frame on 22's?....Please help
lo75lux   +1y
tub the fire wall, move bothe wire harnesses buy each wheel,drop spindles, tubular control arms would be good,window washer fluid box, overflow tank...i prolly missed some but i'll get pic of under my hood leter to post
baggednbad91   +1y
i have found that u also hav to notch the frame for the of rear lower control arm even if they are tubulars. and nothch the upper control arm brackets. but i didnt tub my firewall. but im only runnin a 255/30/22 tire in the front.
willdragforfood   +1y
http://pg.photos.yahoo.com/ph/willdragforfood/album?.dir=/9750&urlhint=actn,del%3as,2%3af,0 there you go pics of my fullsize layin body under the hood on 22s first one done 295 30 22
banginfullsize6   +1y
Will i have to cut and chop the exaust?
lo75lux   +1y
just the y pipe, unless ur cool like me and drag thru it, and ur gonna have to take the spring loaded part of the hood holder upper thingy, i had to and im runnin a 265/35/r22
nvrfnsh   +1y
*tub firewall or just move it back a few inches (i actually just moved mine back with a portapower)
*tie rod notch
*notch frame for lower control arm (it will hit the frame before you lay out)
*notch lower control arm mount (the lower control arm will hit it before you lay out)
*notch upper control arm mount or the uppers themselves (the upper control arm will hit before you lay out)
*relocate the wiring harness connector on the driver side firewall
*modify or remove inner fenders
*relocate or remove coolant overflow tank
*relocate battery or battery mounts
*relocate or remove windshield washer fluid tank
*remove hood springs (will possibly hit)
*drop spindles (of course)
